Estate Jack and Axle Stand Points
Hi All,
I have a 17 Plate Octavia Estate.
I know I can jack from the reinforced points on the sills, im after help where to put the axle stands on the front and back so I can take the wheels off and clean them if anyone has any pictures it would be greatly appreciated.
Thanks!
i use the point just after the suspension link at the back on the chassis rails. i have 6 ton stands which are tall and for a VW bus so its easy to place them further back and away from the side rails. I cant use stands near the jacking points as it would damage my skirts. I don't have any clear images but its just after this link on the rear suspension....
  • 3 months later...
Anyone got any pictures of jacking the facelift Occty estate?
On my pre-facelift Scout, I use a trolley-jack when swapping summer/winter wheels. I use the jacking-points as indicated on the seam behind the sill, with a suitably-grooved block of wood between the nasty, scratchy jack and the soft, bendy car.
I did have a look, but I think the alleged underbody-protection makes access to other points more difficult.
