Superb Limousine LED tailight
I have a 2009 Superb II Limousine with standard taillights and i'm planning to insert the L&K LED taillights instead. But if i just plug and play i know that the bulb warning will show up, and as far as i know there's no option for LED taillights in VCDS.
Have someone else done this before and what did you do? I think it would be best if i could connect a module or a resistor with the original wiring terminals.
Something like this would be great, but these have too many cables and have other terminals.
Bilderesultat for Skoda Superb Dynamic Tail Lights LED Adapter Kit
Edited by 95mathias
The best plan is to use a BCM that supports LED tail lights and have it coded correctly using VCP/ODIS-e. When done properly, there are no bulb warning lights and no resistors are needed.
Got an autoscan showing your current BCM?
See this link, I'd love to do this to mine too:
Thanks for reply langers2k and MarkTB.  I think i will change the BCM, but first i will scan my BCM to check if it support LED tail lights.
langers2k I got the BCM with partnumber 1K0 937 087 A, and as far as i know it dont support LED tail lights, and i cannot find anything in the CAN-gateway installation list.
Edited by 95mathias
