H7 bulbs round 2
last winter i decided to upgrade the main lights and bottled out considering the apparent awkwardness of fitting
but after a horrific drive through the night last february from burnham on sea to bristol airport in wet weather on the A38 through some twisty and badly lit roads...watching my low low K value original bulbs tempt me off the road at times!!
i will now do the necessary and upgrade....i guess my oem bulbs are 55W but have low K temp output..sort of off white and orangey in the wet:-
the new ones will have to have extra apparent output as a percentage and a "whiter" high value K output colour
starting off
i saw... H7 OSRAM Night Breaker Laser 150% Next Generation 12V 55W (Pair)...£26.40 on the internet...
they are Xenon gas so seem to be "regular" bulb technology...avoiding the LED route
i just want to fit them exactly as the existing bulbs...which could be spare for an emergency
all help welcome and thanks in advance
geof
Edited by mrcrow
Hi mrcrow.    Over the years I have tried various upgraded H7 bulbs, Osram Night breaker, Phillips ex-treme etc. Generally I got some good improvement over standard ones, but these upgraded bulbs are known to not last that long, as I found out. I usually got between 1year or maybe 18months. The upgraded bulbs I have fitted now are RING xenon 150, advertised as not having the usual problem of a short life. So far they have lasted around 15months, so can't comment on their long life just yet. What I can state with confidence, is they are far better than the standard bulbs, I even think they are just about the best upgraded bulbs so far for performance.
massive step forward...i cant do another winter on our country roads with wonderboys coming toward me with their xenons and chaps following me wishing me on with these present bulbs warning me to slow down
cheers and a big thanks
changing them if they do fail will have to be my option as a default
cheers
geof
Just an update on the above statement on the Ring bulbs. Although they are in my opinion a great bulb for extra light output, they don't really last that much longer than other upgraded bulbs. Just had one blow today. Mind you, I like them so much, I have fitted another set of Ring  H7 bulbs to replace them.
is it the same bulb which goes?
i hear this quite a lot about bulbs going....on my golf 2001 1.6S no bulbs ever went for 8 years till i upgraded them to brighter ones i bought from awesome GTI in manchester...make is the ones they fit to performance cars..which were ok when i sold it 7 years later..must have been lucky
are you in the countryside...might have asked you that before
on those speed humps i change right down to 1st gear and go over easy
cheers
geof
cheers
geof
I am near the countryside and do at least 20k miles a year. Speed bumps, I also go over slowly, especially with the firm suspension of my VRS. All these upgraded bulbs do not last long, but they are worth it in my opinion for the improved performance over standard ones. I was just hoping according to the Ring adds, these ones would last at least 2 years. Nearly got there mind.
aye!  its the changing them which will put me off...havent tried so far but i need to go out when its dark and see if the ones in the car...55W...are really producing clear and crisp dip and main
otherwise it means i need to change.
we are going to bristol some time so we will be negotiating bodmin moor on the A30...no time to be under lit
cheers
geof
