2011 scout audience shows safe 0000
Is it possible to code using VCDS or does this require trip to the stealers?
I know older units could be done from serial number and some calculators.
What are the fitment codes for the various radio offerings as I suspect the audience is not original unit
Bolero with in built 6 disc CD autochanger came fitted as standard. Climate Control and PDC were displayed on the screen.
Handsfree and Bluetooth were optional extras.
Columbus was the rather expensive optional upgrade.
So the audience has been fitted ro replace a bolero or columbus then.  Still need to know if it can be decoded from serial or VCDS though.
so managed to pull codes from VCDS
RADIO advanced ID
Advanced Identification
     Serial number: SKZ7Z4F0008388
     Identification: FO3-000
     Revision: 00013000
     Date: 03.01.06
     Test stand number: 0001
     Manufacturer number: 0001
Flash Status
     Programming Attempts: 1
     Successful Attempts: 1
     Programming Status: 00000000
     Required Conditions: 00000000
     Flash Tool Code: 69794 576 25051
     Flash Date: 01.01.00
Misc.
     Hardware number: 1Z0 035 156 B
     Lot Number: 000
     Type Lock: 0000
VCDS Info:
       Labels: 1K0-035-1XX-56.LBL
Is that going to need a paid decode or will the free databases cover that being  an older unit?
Also does anyone have the option codes that correspond to the radios/nav
found these on the options sticker:
8AG    RAO    Radio with CD/MP3
8L5    ANT    Roof antenna and "diversity" window antenna
8RM    LSE    8 speakers (passive)
7Q0    NAV    Without navigation device
