Tyre problem
Hi all just had a warning on the dash check tyres checked all tyres and warning still on any idea on how to help
What did you check just the tyre pressures when cold?
Are they at the same pressure as when you set them last when cold and set the TPMS?
 Have you reset the TPMS now with the pressures as they are?
If you have then hopefully if no leak / puncture there will e no warning.
Brakes binding can cause a wheel so the tyre to get hot and then a TPMS warning as the tyre size changes.
Edited by Offski
How do you reset tyre pressure monitor system I didn't know you could
First is setting, that surely was done sometime, then resetting as you change tyres, pressures etc.
It will be in the Owners Manual for your car how to.   Not complicated though what ever car.
The sorted there is a reset button at the side of the gearstick thanks anyway
