MAF readings Yeti 81kw diesel 2.0
Hi guys, having some troubles with my Yeti lately. Every now and than have a problem with starting. Seems as if it started with 3 cylinders no power whatsoever. Stalls. A lot of smelly white smoke. Give it 10 mins and it starts fine. Been looking at MAF readings and it says 12g/s idle and averages about 37g/s around town. Are these standard? Already replaced plugs, injectors, return tubing atc, in tank pump. Running out of ideas. Any suggestions? Thanks
Have you tried reading what fault codes there are?
P0193 high fuel pressure. Have replaced a fuel sensor too. No difference
Which would suggest that there is something wrong with the pump and not all the things you have replaced.
I used to feel I could fiddle around and fix anything but now I just get a dealer quote and check my bank balance.
Although expensive sometimes cheaper in the long run.
