Mk2 pfl G69 tfsi help
Hi all.
Got an annoying fault on my 2008 vrs tfsi pfl bwa 200bhp. I've changed the pedal as showed a pedal fault first. Now put a replacement throttle body on (second hand). Drives okay until you put foot down and comes up with below fault?!!?.
Any ideas at all of other things to check or replace.
OBD2 - pending:
P0123 - Throttle/Pedal Position Sensor/Switch "A" Circuit High
Engine:
P0123 - Throttle Position Sensor (G69), Signal too High
I can reset codes and drive gently around but on a run or motorway etc comes back.. Jerky and epc light limp mode
Regards
Ant
