Reseting/Setting the service intervals ?
Is it possible in the Octavia 2 (maxidot)  to dissapear days left from service reminder intervals and set the mileage to standard 10k  (rather than currently 15k)  whenever pressing the reset via the menu in the maxidot?
tried with VCDS but in the SRI function of VCDS it only shows ESI (north America) and FIX/ESI (north America) only those 2 otpions which seems to be standard resetings.
In the 17-Instruments module the FIX: distannce covered since last mileage-dependent inspection and the FIX: Timesince last time dependent inspection shows that both options the "channel not supported" like message and do not let me enter the preffered values i wish.
Any other ideas or something?
So no anyone to know that bit ?
I think you can change these adaption channels:
Quote
ESI: maximum value km-driving distance/inspection,30000 km
ESI: maximum value of time between inspections,744 d
ESI: minimum value km-driving distance/inspection,15000 km
ESI: minimum value of time between inspections,744 d
They may have slightly different names if you're on fixed rather than variable servicing.
Can you post an adaption map of 17 (ideally CSV) as it might help.
Ok thanks, but those above seem not to be what would like to use..
 Anyway I'll attach the 17 adaptation maps upon find some time to do so and in csv file to see how this could help.
Cheers!
Edited by AkisVH
