Error code
Hi I'm hoping someone can help me I've got a engine management light on my 59 plate skoda fabia with the 1.2 engine I've had a dianostic computer on it and it's come up with error code po172 bank 1 too rich. I've checked everything I can think of including the 2 O2 sensors the coil packs spark plugs air filter but it still keeps coming on
You sure that code is correct ?? this was a "dummy scanner" I assume ?
Thats a generic OBD II code basically refering to not enough oxygen in exhaust, could be many things.
I think is it needs a scan from a VAG tool like VCDS or the dealer to get a proper diagnosis
From Ross Tech
16556/P0172 - System Too Rich, Bank 1
Possible Symptoms
  • Irregular behavior
Possible Causes
  • Fuel system
  • Excessive fuel pressure
  • Leaking or contaminated fuel injectors
  • Leaking fuel pressure regulator
  • Low fuel pressure or running out of fuel
  • Vapor recovery system
  • Air leaks after the MAF
  • Vacuum leaks
  • Improper seated engine oil dipstick
  • Stuck EGR valve
  • Oil overfill
  • Cam timing
  • Cylinder compression
  • Exhaust leaks before or near HO2Ss.
Edited by UrbanPanzer
Cheers I will double check the code number and if that doesn't help I'll get it checked out at a garage
