LED Bulbs
Hi.
Has anyone replaced the bulbs in the headlights and taillights with LEDs?  IF so was it a simple job?
Thanks.
Front bulbs are easy.
tail lights, maybe a little bit of a fiddle to release the securing clip on the back of the
connector plug at the back of the light cluster. Don't try to pull the complete tail lights unit out of the body work if you HAVE NOT disconnected that plug. Disconnect it first, undo the butterfly nut at rear of the unit and the whole light will come out with ease.
Some LED bulbs might show errors in the VCDS scan.
