Deleting a “flagged destination”
I have the Amundsen Infotainment.
Following the instructions from the manual regarding the satnav:
”Delete destination
▶ In the Navigation main menu, tap the function surface  → Destinations.
▶ Tap the function surface  and select the desired list of destinations.
▶ Show the destination details by tapping on the function surface  at the de-
sired destination.
▶ Tap the function surface Edit .
▶ Tap the function surface Delete and confirm the deletion.”
...this works for saved destinations. However I have a destination that is a “flagged” one i.e. one created by touching the screen when the car is at the place you want saved. The above instructions from the manual then don’t work because there is no “Edit” option.
How do I therefore delete a “Flagged” destination.
Tom
Looks like I have managed to answer my own question!
You cannot delete a “Flagged” destination, it can only be overwritten by the next use of the “flagging” system.  See:
“Flagged destination” Save (current vehicle position)
▶ In the Navigation main menu, tap the function surface  → Store → Store cur-
rent position.
▶ By then pressing the function surface Rename the flagged destination can be
renamed and stored as a destination in the dest. memory.
By storing the next flagged destination, the last flagged destination will be overwritten. To maintain the existing flag destination, this destination must be stored in the Infotainment memory.”
Tom
  • 7 months later...
HI to delete flagged destinations go to delete home address tap on manage memory  /tap delete user data/ a list will appear. One of which is delete flagged destinations/ tap delete and your flagged destinations should be gone/ hope this helps you.  Cheers.
Thanks, will try that.
Tom
