Fitting Fabia door and window pillar trims, is it easy??
I have a Fabia Classic and want to fit a few bits and pieces to it, like the door trims and protection strips below, and maybe mudflaps. Not exactly going to get it on the cover of Max Power :P but I just think my car is a bit bare, and I'm don't think putting a spoiler on a Fabia Classic is going to fool anybody!!.
Window trims Part No. KGA410001
Door strips Part No. KDA400002
Are they easy to fit or is it best to get them put on by the dealer??
the pillar trims are a bit fiddly but easy enough to do
i aligned them up before removing the backing paper and used masking tape to keep them in position before pulling the backing off bit by bit - smoothing them out (with free plastic scraper in kit) - just make sure the're level top and bottom
for side mouldings i suppose the easiest way to fit these is to put masking tape just below where the moulding goes - keep peeling it off and re-sticking until it's spot on then you have an accurate guide for the rubber :)
i fitted piller trims.... and yup they are quite easy.... best thing i can say is don't rush it and u'll end up with a great job.
