Coding out ESP
I'm just wondering if anyones worked out a way to code out the ESP with the Traction Control?
Since using track tyres and being able to carry more speed through corners the ESP is becoming rather intrusive even more so at knockhill when going through the chicane on 2 wheels and in the wet where it isn't very consitant but i still want to keep the ABS.
I've found this but this didn't work on the Fabia
https://www.goapr.com/support/esp-defeat.html?fbclid=IwAR1FuITc4NUWFeQutW5nD24P-noWwPhE4mDlqFN9cbXqNeyGuBJ1novqUos
i know i can pull the fuse which will also turn off the ABS but when i went to pull that at a sprint recently which in the manual said it was fuse 48 which mine doesn't have.
This will purely only be done on track where the car is running track specific tyres (Avon ZZR's).
