Octavia II 1.9TDI, red power steering icon, VCDS
Hi everyone,
I have this power steering issue with my Octavia II 1.9tdi 2007. I have drained my battery in winter and had first this orange power steering icon on dash which turned into red icon after connecting VCDS to the OBD port. I think at first the adaptation went wrong after the dead battery. Also I think I have deleted the adaptation with VAG CAN PRO. I have this vag can pro and vcds interface.
Maybe someone had a similar issue with the power assist and can share how I can fix it ?
The power assist works but not as good as it should, have to put  more power to turn the steering wheel and there are three beeps after turning on the ignition straight away.
Here are some fault codes I was able to read with VCDS:
Chassis Type: 1Z (1K0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
1 Fault Found:
005785 - Powertrain Data Bus            P1699 - 000 - Missing Message from Steering Wheel Electronics         Freeze Frame:                Fault Status: 01100000                Fault Priority: 0                Fault Frequency: 192                Reset counter: 255                Mileage: 267987 km                Time Indication: 0                Date: 2000.00.00                Time: 00:04:39
         Freeze Frame:                RPM: 798 /min                Speed: 0.0 km/h                Load: 0.0 %                Voltage: 14.21 V                Bin. Bits: 11001100                Bin. Bits: 00000000                (no units): 0.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl   Part No: 1K0 907 379 P   Component: ASR FRONT MK70      0105     Coding: 0017025   Shop #: WSC 73430 790 00000   VCID: 3F8DF5FD6E7DBBB2EC-806A
2 Faults Found: 00668 - Supply Voltage Terminal 30         002 - Lower Limit Exceeded - Intermittent 00287 - ABS Wheel Speed Sensor; Rear Right (G44)         012 - Electrical Fault in Circuit
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb   Part No: 1K2 909 144 L   Component: EPS_ZFLS Kl.068 H07 1806     Shop #: WSC 02069 000 90108   VCID: 356197D55C4171E236-8060
2 Faults Found: 02546 - Steering Limit Stop         005 - No or Incorrect Basic Setting / Adaptation         Freeze Frame:                Mileage: 267980 km                Temperature: 22.0°C                Voltage: 14.40 V                Voltage: 14.20 V
00778 - Steering Angle Sensor (G85)         000 -  -          Freeze Frame:
Have you driven it 50 yards in a straight line yet?
They normally throw up the code when the battery is low or removed and the light goes out after driving a short distance.
Yes, I drive the car every other day. Also I did try this adaptation process before, where I turn the wheel right, left, straight. But I drive the car with this red icon and need it sorting for my next MOT :) also I have removed the battery and charged it with battery charger at home.
