Window regulator
Hi all
can you help with a small query
have problem with drivers window
attended local Skoda main dealer
diagnosed replacement regulator
initially hit with €80 diagnostic fee
advised this would be consumed into end price if work went ahead
hung around,sweetened up with paper coffee and croissant
then advised that the regulator needed replacing
fortunately has in stock........part and labour €302!!!
this sounds a bit dear but have to get fixed ; any opinions would be great,thanks again in advance
What's the breakdown on parts vs labour? It doesn't sound ridiculous for dealer work tbh, there's probably an hour and a half minimum in labour, which is half that amount straight off the bat.
Ok fair enough
got it for €280 in the finish
I guess someone has to pay for the big glass showrooms !!!!!!
I had mine done a couple of years ago, I fell through the floor when I got my bill, both needed doing at the same time
Not had to do one on mine yet, if it’s the same as my A6 Allroad it’s a PITA.
the door frame unbolts and the unit is riveted to the frame. The rivets are drilled out and you need a motha of a rivet gun to fit the genuine rivets. I broke my rivet gun on the fourth rivet, luckily as it popped.
Sounds a fair price to me for the dealer to do it.
