What is error code P190D on Mk3 Skoda Octavia 2.0 TDI
Hi there can anybody tell me what error code P190D is on my Mk3 Skoda Octavia 2.0 TDI 2014
had the eml come on the other day, got it cleared by a mate yesterday but it’s come on again today
The car is still running fine, no limp mode or any other warning light
your help is appreciated
cheers
Neil
Quick update just been on the VAG website and ive come across the code,
Which pump is this and does anybody know what the solution might be?
you beat me to it.......
From what I've read, the pump is shot and needs replacing unfortunately.
Is this the pump that gets replaced when you get your cambelt and water pump done? if so ill be making a call to my local garage tomorrow as they changed my belt and pump only 6 weeks ago!
I'm not sure. I wouldn't wish to say in case I'm wrong.
I can't make out whether it's something to do with the AC circuit or the engine. Just been having a look at some of the other error codes say 'engine coolant' which I'd assume to be the normal radiator loop.
The car went back to Skoda under warranty around a year ago as eml had come on and that time there was a short, showing low voltage in a wire connecting to the air con/heater pump
this was fixed and no problem since up until last week
If I remember right they said there was two or three pumps on the car?
If you google it the golf version comes up, looks like a little electric pump which would figure as the other errors refer to electrical connection.
Thanks do you have a link?
Well at long last got my EML issue sorted, it wasnt the pump as first suspected but some dodgy wiring repair that was supposedly fixed under warranty at Skoda Autosales Burntwood where i got the car from, thankfully one of my mates who knows what he is doing fixed it for me at a cost of £12 for the part and £20 beer money 😉
So here is the part on the car
the outer yellow wire just fell out and part of the pin had broke off in the connector, you would of thought they would of fitted i new 3 pin connector?
Anyway new part was ordered and fitted in 20 minutes so all good now
Cheers Neil
  • 7 months later...
Is there a link or place where you get it from? Would be very handy at this moment as I need same one.
Have you by any chance got a link to the new 3pin connector?
I got mine from scrap yard instead of buying online as all I could find was aftermarket connectors. Got serial numbers so you find it easier online as there are plenty different connectors looking quite similar.
here’s the number: 4F0973703
Hope it helps :)
Post the pictures on Skoda Autosales Burntwood's social media accounts.
A botch is a botch, and unless we call them out they'll continue to do it for as long as they think they can get away with it for.
