Airbag light
Airbag light is on. Scanned showing no codes so cant erase the light. Puzzled now checked connections under seats all good
Have you checked the drivers door loom?, that's also a favourite to go as well.
Hope this helps,
Trev AKA Aston Bodger
I'd be very surprised if the airbag light was on without any fault codes.
Are you using VCDS or similar?
Yes, what kind of scanning did you use?
I've heard that only VCDS helps. Some kind of small OBD devices with Carista (and similar) are said to be no use at all in airbag case.
