MFSW Retrofit module part number
Want to fit MFSW (3T0 419 091K) to my 2012fl Octavia,  But need highline module. Is there a way I can find out if it is a 5K0 type or 1K0 that is fitted to my car, without taking everything apart?
Scan it with VCDS or similar 🙂
Okay, so have steering wheel (3T0 419 091 K E74) from 2011 Octavia, slip ring (5K0 953 569  AL) from 2014 Audi A1, and wiring loom 3T0 971 584 A (new) all fitted. Steering module (not slip ring) was code previously in prep for mfsw retrofit.
trip computer on stalk and cruise on other stalk no longer working. Q. Would the slip ring be too new for my Octy (2012)?
scan with vcds :
Friday,05,July,2019,18:38:54:25882
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.0.5 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: TMBBE21Z2C2148405   License Plate: FE12HFT
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72 77
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Not registered 0011
Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 C    HW: 03L 906 018 BR
   Component: R4 2.0l TDI   H24 9978
   Revision: 42H24---    Serial number:
   Coding: 00190012042500080000
   Shop #: WSC 50918 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018C 003008
   ROD: EV_ECM20TDI01103L906018C.rod
   VCID: 2A5140CB4D9A331FE8-807E
No fault code found.
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0106
   Revision: 00H35001
   Coding: 0017665
   Shop #: WSC 73430 790 00066
   VCID: 7BFFB58F3A807A97C3-802E
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 BK    HW: 3T0 907 044 BK
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7CFDB693F78E7DAFCA-8028
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
   Component: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Coding: 48000AB8A85BB1C0401000801100856D432000AE726D81605C8440000040
   Shop #: WSC 63804 001 1048576
   VCID: 3F87019FAE18A6B7AF-806A
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 27011  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 130212 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
1 Fault Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 39
                    Mileage: 40323 km
                    Time Indication: 0
                    Date: 2013.14.18
                    Time: 14:08:04
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.90 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32901204103031
   Coding: 10800E
   Shop #: WSC 13765 790 00066
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000_001.rod
   VCID: 336F5DAF9A5072D75B-8066
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2V2SZI
   Coding: 0020788
   VCID: 3D7B7B976414B4A7BD-8068
   Subsystem 1 - Serial number: 6332MSME68517754E
   Subsystem 2 - Serial number: 6342MSME6A4036359
Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 AL
   Component: LENKS.MODUL   016 0140
   Revision: FF010018    Serial number: 20140703300534
   Coding: 1184004000
   Shop #: WSC 00046 412 00000
   ASAM Dataset: EV_VW360SteerWheelUDS A03004
   ROD: EV_VW360SteerWheelUDS.rod
   VCID: 39736F87B83C888791-806C
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 903 S    HW: 1Z0 920 903 S
   Component: KOMBI         H05 0607
   Serial number: 00000000000000
   Coding: 410E00
   Shop #: WSC 73430 031 00066
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 458B1377C4C4FC67E5-8010
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 070212F1001282
   Coding: 351303
   VCID: 3A71708BB53A839F98-806E
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 255
                    Mileage: 40744 km
                    Time Indication: 0
                    Date: 2013.14.30
                    Time: 14:12:60
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 0607
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD180CB8D1AF31F28-803E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 3T0 035 680 A    HW: 3T0 035 680 A
   Component: RNS-MID       H42 2724
   Revision: AB001001    Serial number: SKZ6Z7K4303002
   Coding: 040004020401008100
   Shop #: WSC 33361 790 00076
   VCID: 2E594CDB79725F3F34-807A
2 Faults Found:
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 0 km
                    Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 94
                    Mileage: 0 km
                    Time Indication: 0
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2120
   Coding: 0000758
   VCID: 76E9A4BB01A227FFBC-8022
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   VCID: 377769BF46289EF767-8062
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0000758
   VCID: 48951A433BD6E10F1E-801C
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 94
                    Mileage: 0 km
                    Time Indication: 0
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012546
   VCID: 326158ABAD4A7BDF50-8066
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 336F5DAF525072D75B-8066
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007662835187
   Coding: 0A01000000010101
   Shop #: WSC 00028 028 00025
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
End-------------------------(Elapsed Time: 02:48)--------------------------
Address 16,8X0 953 501 B,recoded (Long Coding),from,1184004000,to,1184204000,(00046/412/00000),
Address 09,1K0 937 087 Q,recoded (Long Coding),from,48000AB8A85BB1C0401000801100856D432000AE726D81605C8440000040,to,46000AB8A85BB1C0401000801100856D432000AE726D81605C8440000040,(63804/001/1048576),Friday,05,July,2019,18:57:32:25882
www.Ross-Tech.com
   Revision: 00H35001
   Coding: 0017665
   Revision: 00001007
   Coding: 0000000002
   Revision: 00110 AC
   Coding: 46000AB8A85BB1C0401000801100856D432000AE726D81605C8440000040
   Coding: 00D7B7
   Coding: 0730ED
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 39
                    Mileage: 40323 km
                    Time Indication: 0
                    Date: 2013.14.18
                    Time: 14:08:04
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.90 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
   Coding: 10800E
   Coding: 0020788
   Coding: 1184204000
   Shop #: WSC 00046 412 12345
   Coding: 410E00
   Coding: 351303
1 Fault Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 1
                    Reset counter: 255
                    Mileage: 40744 km
                    Time Indication: 0
                    Date: 2013.14.30
                    Time: 14:12:60
   Coding: 000000
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 94
                    Mileage: 0 km
                    Time Indication: 0
   Coding: 0000758
   Revision: 00H22000
   Coding: 0000758
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 94
                    Mileage: 0 km
                    Time Indication: 0
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 02:46)--------------------------
Gateway Installation List:  7N0 907 530 M
37-Navigation -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 19,7N0 907 530 M,recoded (Installation List),from,E9A07F064002020000,to,E9A07F064006020000,,
Address 19: DTCs clearedFriday,05,July,2019,19:08:15:25882
www.Ross-Tech.com
19-CAN Gateway -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
   Revision: 00H35001
   Coding: 0017665
   Revision: 00001007
   Coding: 0000000002
   Revision: 00110 AC
   Coding: 00D7B7
   Coding: 0730ED
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 55
                    Mileage: 46515 km
                    Time Indication: 0
                    Date: 2020.14.01
                    Time: 06:57:23
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.55 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
   Coding: 10800E
   Coding: 0020788
   Coding: 1184204000
   Coding: 410E00
   Coding: 351303
   Coding: 000000
   Coding: 0000758
   Revision: 00H22000
   Coding: 0000758
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 02:45)--------------------------
Address 16,8X0 953 501 B,recoded (Long Coding),from,1184204000,to,5184204000,(00046/412/12345),
It's not because the module is newer, it's because the Audi software is designed for different stalks to those fitted in an Octavia.
It's the same issue as the other thread: https://www.briskoda.net/forums/topic/468487-2011-fl-mfsw/ Personally, I'd sell the Audi module and buy the right one...
If the new module also came with stalks, you should be able to figure out how they work easily enough (it's a resistor ladder) and possibly modify the original stalks to match their behaviour. I did the same recently when I fitted MK3 style stalks to my FL MK2 :)
I wonder if there is a flash file you could use to change them
Part number is correct
I also wonder if using a different tool to try coding
Yes, I wondered if it was possible to reset the module. Trundlenut did the scan and tried to code, but the only options for CC were not fitted or separate stalk (as per Audi).
Also buttons on mfsw not working.
Oh and thanks to both langers2k and Eddie-NL for the replies/advice.
Just did a quick google and it turns out their are various flash files for 5K0 953 501 N. There are five versions, one for Audi, one for Seat and three different ones for VW but nothing that's labelled for Skoda.
At least one person has used these on a 5K0 953 501 AT/5K0 953 569 H HW:016 steering module to go from SW:0140 to SW:0180 in their Tiguan. I think it may only be suitable for cars needing a EV_VW360SteerWheelUDS A03004 dataset though? Link: https://www.drive2.ru/l/533043787975360516/
Oh - just found there is an update for 5K0 953 521 J  that seems to be for Skoda SW:0136...
edit:
SW:0136 looks like it'll probably be too old for the AL rev hardware. From what I can see it'll only work on HW:009 😕
Edited by langers2k
Would it be of any benefit to reinstall old module to check coding?
Have you sorted it?
19 hours ago, Eddie-NL said:
Have you sorted it?
Have tried 5K0953569E, and everything seems to work. This module does not have steering angle sensor. Will that cause problems? Original was 569C
Edited by Teedeeaye
Shouldn't do.
Your car has the sensor in the steering rack based on the original autoscan 🙂
1 minute ago, langers2k said:
Shouldn't do.
Glad you sorted it, a bit late for you but I know how to fix the problem you had with the Audi version
Go on then tell me...I still have the Audi module.
do you have vcp?
