CANBus Not working
I have a Skoda Fabia Mk2 (2008). Last year I had some issues with my sliding roof being pretty leaky (might be related to this issue). I've posted the issue on this forum.
Now, I think I have some issues with my CAN wiring.
Last year, I've went to a full servicing and the guy there told me that he tried to hook in his diagnostic tool, but it did not work. I didn't mind as I knew any error codes.
I have a VAG12.12 myself and communication only works using KWP2000. If I try Auto-Scan (forces CAN), it can't find anything; similarly, if I choose the model and check 'CAN only' it fails to communicate.
I'll do check the resistance between CAN L and CAN H (pin 6 and 14) tomorrow to see if it's right.
Although, I'm pretty sure that the CAN wiring is messed up.
Everything else works fine, except for the parking sensors;
Also, if I have my heating on and I go into Reverse, the fans would start spinning even faster for no reason -- definitely noticeable.
What do you think?
If you think it's the wiring, do you have any recommendations on where to buy a wiring kit?
Thanks a lot :)
Here's the log of an auto-scan with VCDS. I think the Radio fault is because I have installed a custom head unit
Chassis Type: 5J (5J - Skoda Fabia (2007 > 2010))
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 B    HW: 03C 906 024 F
   Component:  MARELLI 4HV      G 0896
   Revision: --H05---    Serial number: SKZ7Z0G4276574
   Coding: 0000071
   Shop #: WSC 13765 790 00000
   VCID: 1D313FFFC74415F69F5-5000
No fault code found.
Readiness: 0110 0001
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.lbl
   Part No SW: 6R0 907 379 C    HW: 6R0 907 379 C
   Component: ABS 8.0 front   H05 0002
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0002127
   VCID: 3E73D8736A826EEEA6F-50E6
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 5J0 907 044 A
   Component: CLIMAtronic SK25    0608
   Shop #: WSC 00000 000 00000
   VCID: 285F1E2B9806C05EFC3-5072
1 Fault Found:
00792 - A/C Pressure Switch (F129)
            000 - -
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 F
   Component: 0000 BN-SG.         2S36
   Coding: 25742
   Shop #: WSC 13765
   VCID: 3E73D8733A826EEEA6F-50E6
2 Faults Found:
01327 - Control Module for Parking Aid (J446)
            49-10 - No Communications - Intermittent
01304 - Radio
            49-00 - No Communications
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 F
   Component: QA AIRBAG VW61 Q5Q6 0004
   Coding: 20801
   Shop #: WSC 13765
   VCID: 275D1D17C518CF26F59-5000
1 Fault Found:
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 5J0-920-xxx-17.clb
   Part No: 5J0 920 940 B
   Component: KOMBIINSTR.    V2824486
   Coding: 19403
   Shop #: WSC 13765
   VCID: 29591B2FD30CF956E3D-5072
1 Fault Found:
01304 - Radio
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 000E GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 13765
   VCID: F0EFB64BB056489EE43-50E6
2 Faults Found:
01304 - Radio
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER    V2824486
   Coding: 19403
   Shop #: WSC 13765
   VCID: 29591B2FD30CF956E3D-50E6
   TMBDC65J183049831     SKZ7Z0G4276574
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10140
   Shop #: WSC 13765
   VCID: 6FED35372D68D7667D9-5072
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 5J0 959 433 A
   Component: 03 Komfortgerát     0001
   Coding: 00018
   Shop #: WSC 13765
   VCID: 3169F34FFBDC81962BD-4A3A
1 Fault Found:
01135 - Interior Monitoring Sensors
            36-10 - Open Circuit - Intermittent
Address 76: Park Assist        Labels: None
   VCID: 55A167DFBFF48DB6975-5072
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
End   ---------------------------------------------------------------------
Edited by CptChix
If you can access Gateway then CAN is working fine. A 2008 Fabia doesn’t run full CAN that will auto detect all control modules. It still uses the central electrics control unit from the Fabia1 which contains gateway.
The fan note will change when selecting reverse. It closes air recirculation by design.
Edited by Tech1e
