Random Errors 1.8 TSI Combi 2010
Hello the car is randomly going into limb mode some times and after some time of use, could be 30 minutes or 2 hours or 2 days the car start to act weird, EPC light goes on and limb mode, previously the dealer changed the ABS unit 2 months ago free in a campaign. I suspect it is a problem with the main ECU because after the car is in the limb mode I erase the faults with VDCS cable and car most of the times runs again as if nothingh happenned, some days after or 1 hour after starts again with the problem. Please give me any advice, the car is out of warranty..
This is the main fault report
Address 01: Engine (CDA)       Labels: 06J-907-115-CDA.clb
   Part No SW: 3T0 907 115 H    HW: 1Z0 907 115 F
   Component: 1.8l R4/4V TFSI     0010
   Revision: AAH06---    Serial number: 00000000000000
   Coding: 0203000024070160
   Shop #: WSC 35032 002 1048576
   VCID: 36634CBE418657F24A-8062
3 Faults Found:
000545 - Angle Sensor 2 for Throttle (G188)
               P0221 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 74964 km
                    Time Indication: 0
                    Date: 2013.11.01
                    Time: 21:21:60
             Freeze Frame:
                    RPM: 3211 /min
                    Load: 25.5 %
                    Speed: 36.0 km/h
                    Temperature: 99.0°C
                    Temperature: 45.0°C
                    Absolute Pres.: 750.0 mbar
                    Voltage: 13.462 V
000289 - Throttle Position Sensor (G69)
               P0121 - 000 - Implausible Signal - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 75028 km
                    Time Indication: 0
                    Date: 2013.11.11
                    Time: 01:14:53
             Freeze Frame:
                    RPM: 1511 /min
                    Load: 37.2 %
                    Speed: 46.0 km/h
                    Temperature: 95.0°C
                    Temperature: 36.0°C
                    Voltage: 13.716 V
005445 - Throttle Valve Controller
               P1545 - 000 - Malfunction - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 74974 km
                    Time Indication: 0
                    Date: 2013.11.03
                    Time: 22:06:40
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 16.0°C
                    Temperature: 23.0°C
                    Voltage: 11.938 V
Readiness: 0010 0000
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0109
   Revision: 00H45001
   Coding: 113B401C0A220000880B02E6501A0041A900
   VCID: 000FEA6693C22942A0-8054
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory
             Freeze Frame:
                    Fault Status: 01101101
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 210
                    Mileage: 74964 km
                    Time Indication: 0
                    Date: 2013.11.01
                    Time: 21:22:01
             Freeze Frame:
                    Count: 0
                    Count: 32768
                    Count: 4608
                    Count: 8193
                    Count: 48933
                    Count: 1036
                    Count: 0
                    Count: 0
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3T0 820 047 H    HW: 3T0 820 047 H
   Component: Climatic      130 0203
   Revision: 00004001
   Coding: 0000000000
   Shop #: WSC 73430 790 00999
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_SK35.rod
   VCID: 346776B69FFA45E274-8060
1 Fault Found:
9477141 - Position Sensor for Air Distribution Flap Motor
          B109C 15 [008] - Open or Short to Plus
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 248
                    Mileage: 74991 km
                    Date: 2019.06.20
                    Time: 21:08:00
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 46: Central Conv.
Cannot be reached
End-------------------------(Elapsed Time: 02:12)--------------------------
Mate, did you happen to get this solved? I almost have the same issue like what you have.
I have a fault code on Throttle valve controller, Throttle position sensor and ABS - ECM (01314).
I just bought a new EVAP purge and will replace over the weekend so I will see if the throttle error will go away.
I have cleaned the throttle body so I'm pretty sure there is nothing wrong with it.
I'm thinking whether these errors are all linked together.
Thanks in advance!
No this is not resolved, I will replace the Throttlle body connector as I was adviced by someone, this is the part I found,
1J0 973713, 5N1 973206, 4H0 973713
Fitment Type:
Other Part Number:
1J0973713, 5N1973206, 4H0973713
I still waiting for the delivery, it is weird nobody knows this or have the information in briskoda
  • 1 year later...
Hello,
Same repeating dtc I have also:
4 Faults Found:
004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
               P1297 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 8
                    Reset counter: 255
                    Mileage: 159482 km
                    Time Indication: 0
                    Date: 2015.05.05
                    Time: 21:03:43
             Freeze Frame:
                    RPM: 1374 /min
                    Load: 11.8 %
                    Speed: 57.0 km/h
                    Temperature: 77.0°C
                    Temperature: 25.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.097 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 160761 km
                    Time Indication: 0
                    Date: 2015.05.05
                    Time: 18:20:25
             Freeze Frame:
                    RPM: 1537 /min
                    Load: 29.0 %
                    Speed: 22.0 km/h
                    Temperature: 98.0°C
                    Temperature: 36.0°C
                    Voltage: 13.335 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 160762 km
                    Time Indication: 0
                    Date: 2015.05.05
                    Time: 13:25:29
             Freeze Frame:
                    RPM: 802 /min
                    Load: 16.5 %
                    Speed: 0.0 km/h
                    Temperature: 33.0°C
                    Temperature: 7.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.224 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 160760 km
                    Time Indication: 0
                    Date: 2015.05.05
                    Time: 18:15:55
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 102.0°C
                    Temperature: 60.0°C
                    Voltage: 11.684 V
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 113B401C0A2300FF881302E6501C0041690000
   Shop #: WSC 01357 011 00200
   VCID: 7BF59D8AFA244A9AF5-802E
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 55
                    Mileage: 160762 km
                    Time Indication: 0
                    Date: 2015.05.05
                    Time: 13:25:30
             Freeze Frame:
                    Count: 0
                    Count: 0
                    Count: 12800
                    Count: 8193
                    Count: 51712
                    Count: 0
                    Count: 766
                    Count: 0
Did you solve the issue with replace the Throttlle body connector?
  • 1 year later...
Hi !
Does someone have this issue fixed ?
I'm getting the very same behavior of my Mk 3 O3 RS (2.0 TSI CHHA), random rough operation at restart and then limp mode + EPC light. Only P1545 fault recorded. Once the fault is cleared, runs perfectly ...
I've already replaced the throttle body ...
