Info swap to headlight Monte-Carlo on the rs
Hello sorry for my english I am from Belgium ..
I need your help
 I have mounted headlights fabia monte carlo on my Fabia
I have no longer a long-range headlight
You will need to wire them up completely as they use a seperate bulb for full beam, the RS doesn't, or you will have to re-pin the headlight connectors to move the feeds around.
Out of interest , why have you swapped ?
Thank you
I find that the black headlights are much more Beautiful.
I can not find a tutorial 😞
21 hours ago, Arold10 said:
Thank you
 ahhhhh, your post read the other way....
So you have fitted vRS headlights into the monte carlo ?
the wiring this way should be simpler.........will have a look at wiring diagrams, probably just a case of moving pins in the plugs.
