Help needed
I have had the car checked by a very professional mechanic and this is the result. J would like to hear your recommendations. Skoda Yeti 1.4 TSI 2011 90kw
3 error codes found:
 4096 - Bank 1;  Nockenwellenpos.  (G40) / Crankshaft Position Sensor (G28)
           P0016 00 [237] - wrong assignment
           Warning light ON - confirmed - checked since last deletion
              Environmental conditions:
                     Error status: 00000001
                     Error priority: 2
                     Error rate 1
                     Engine speed: 731.50 / min
                     Normal load value: 27.8%
                     Vehicle speed: 0 km / h
                     Coolant temperature: 67 ° C
                     Intake air temperature: 36 ° C
                     Ambient air pressure: 940 mbar
                     Voltage terminal 30: 13,688 V
                     Lost counter to OBD: 40
                     Camshaft adjustment Inlet Bank 1: Specification: 19,500 °
                     Camshaft adjustment Inlet Bank 1: Actual value: 19.500 °
                     Engine coolant temperature at engine start: 69.0 ° C
                     Camshaft adjustment inlet Bank 1: Control: 6.250%
                     Engine oil temperature: 54.8 ° C
                     Camshaft adaptation Inlet Bank 1: Phase angle: -678.93 °
                     Differential angle actual set camshaft position: 0.000 °
 2837 - Fuel system (Bank 1) Rail / system pressure too high
           P0088 00 [237] - -
                     Error priority: 2
                     Error rate: 22
                     Engine speed: 752.00 / min
                     Normal load value: 26.3%
                     Coolant temperature: 69 ° C
                     Voltage terminal 30: 13,640 V
                     Fuel pump: Specification: 42.119%
                     High fuel pressure: Specification: 5.0135 MPa
                     Fuel temperature: 66.8 ° C
                     High pressure control: Adaptation value: 0.5840 MPa
                     High-pressure fuel: control deviation: -8.2315 MPa
                     Lambda Sensor Bank 1 Probe 1: Voltage: 1,494V
 2839 - Fuel pressure regulating valve (N276)
           P2293 00 [236] - mechanical error
           Warning light ON - Sporadic - confirmed - checked since last deletion
                     Error priority: 2
                     Error rate: 19
                   Engine speed: 751.50 / min
                     Normal load value: 23.5%
                     Coolant temperature: 80 ° C
                     Voltage terminal 30: 13.593 V
                     Fuel pump: setpoint: 42.540%
                     High fuel pressure: Specification: 5.0155 MPa
                     Fuel temperature: 70.5 ° C
                     High-pressure fuel: control deviation: -8.2385 MPa
  • 10 months later...
Hi friend,
Did you solve the problem?
Best regards,
Yes. Changed the chain/belt. It was a loose chain
You mean...changed the chain? How many km??
58k km
Now the sound of the engine is like a tesla :)
