Mk2 Fabia Estate exhaust
I'm am beating my head against the wall with this one, simple task, order a replacement exhaust for Fabia MK2 1.9TDI 105BHP 77kw 2008, keep getting  the rear box with 2 pipes out and a different mounting position, the inlet to this box is also quite high and looks like it will foul on the car
The original box is part number 6Q9253609BC which seems to be a single outlet pipe with inlet slightly lower than the other one, but the part number is the same apart from the BC bit
Connecting pipe (middle which goes to Cat is also same number apart from an "A" but this looks ok but not yet tried it on the car as it will have to be cut off at the rear silencer )  so looking for a company that sells the single outlet rear silencer and link middle  pipe, most searches list the pipes for a 1.4 tdi but not the 1.9tdi and when I check it says not suitable,  any help with a suppler would be handy thanks
Tried the local dealer, "sometimes" (not often) they can be cheaper or competetive AND it will def be the correct part.
Call Briskoda parts
Sorry not likely they tried to tell me last time I rang for 2 handbrake cables  that my car 2008 Fabia mk2 did not have rear drum brakes and when I convinced them that they were drum brakes they then told me no way that I had ABS braking system, which it has so   would be very doubtful  they could supply me with the correct exhaust, back box on the mk2 is bigger than the early one with 2 outlets
