Bolero to Columbus or Amundsen. MY2012 vRS
Hi all,
I'm looking to upgrade my Bolero to a Columbus or Amundsen unit. My Octy doesn't have MFSW or a Bluetooth module but does have a MaxiDot display
Could anyone tell me what I'd need to get along with the unit with P/Ns if possible?
Thanks in advance
I have a unit for sale in the Classifieds section, but it's a DAB unit which will be a little more expensive than a standard unit. Comes with the GPS antenna which you'll need, and also you'll need a DAB aerial if you want a DAB unit.
You'll also need a new surround as the Bolero is a different shape, and the one you need will depend on colour and trim etc. of your car I guess.
Then the whole install will need coding with VCDS to make sure everything works correctly (Maxidot instructions, parking sensor display etc.)
Edited by Rustynuts
Doesn't have parking sensors either :(
Would your Columbus accept a rear view camera and a Bluetooth module?
Yes, on both counts.
Excellent, if it’s still available on payday I’ll be hitting you up for it if that’s alright!
Do you have any ideas on the right part number for a compatible Bluetooth module? There seems to be loads of different ones out there.
