Adjusting turbocharger servomotor with a nut on the rod
Anyone could advice me how to correctly adapt turbocharger servomotor in 1.4 TSI 150 PS CZDA by veryfing voltages with VCDS and moving the nut on th rod? Workshop manual for CZDA says the specific value is in the diagnostic device (VAS I suppose), dooesn't mention one. And why I see info "Running|set of parameters not valid and fault at last change" instead of "Done|system OK" (or similar) while testing the actuator with VCDS Basic Settings? Which parameters does it refer to?
Maybe someone would be so kind and check in his own smoothly running CZDA engine voltages for IDE03934, IDE03935, IDE04302 and IDE04303 when the engine is hot? I'd be very grateful.
