Bosch Wiper Blade Choice
Wonder if anyone knows the difference between Bosch Aerotwin and Aerotwin Plus wiper blades? I have used Aerotwin in the past but now am offered both Aerotwin and Aerotwin Plus (for more money), can’t find any definitive info on why Aerotwin Plus is different/better than original Aerotwin. Only difference I can see is that the Plus version comes with different fitments to fit alternative mountings.
For myself, the Aerotwin 'minus' blades are preferable -
1   Cheaper
2   Fitting is simpler as there is no faffing about wondering which mount is the right one.
:mmm:
I use Aerotwin - no issues, simple to fit and work well
This from Bosch.com
Aerotwin Plus: Power Protection Plus
Bosch Aerotwin Plus is a top of the range wiper blade that will enhance visibility in all weather conditions. With its patented coating, longer service life and gentle wiper action, the Aerotwin Plus offers optimum wiper performance, every day.
Perfect wiper performance
Power Protection Plus optimises wiper blade performance throughout the service life of the wiper blade – without leaving streaks or deposits on the windscreen of the vehicle.
Longer service life
Power Protection Plus makes the wiper blade element lip incredibly robust and resistant, as well as increasing its service life. Even extreme heat or cold will have little effect on the wiper blade
Gentle wiper action
Power Protection Plus reduces the co-efficient of friction of the material to a minimum. This means hardly any running noise, no shaking and no shudder whether the driver’s windscreen is wet or dry.
Each Aerotwin Plus wiper blade comes complete with four adapters required to fit ten common wiper arms seen on European and Asian vehicles fitted with flat blades. Bosch’s unique adapter system is simple to use and can be adapted for future requirements.
With fifteen lengths, and covering ten different wiper blade arms, the new Aerotwin Plus range, with Power Protection Plus “PPP” rubber provides perfect wiper performance, long service life and gentle wiper action.
Guess you pay your money and make your choice
