Washer jets not working
Hi I have done some reading and seen that changing fuse 15 seems to fix most problems with the wipers and washers. Changed this but washer jest still not working wipers work fine but no water comes out.
There is also no noise when leaver is pressed so seems like the pump may be dead anyone ells had a similar problem with a possible fix.
Cheers shaun.
There are some pipe connections that often pop apart but if the washer motor is not making any noise it's probably thrown the towel in.
