Towbar coding help
In the original manual for towbar wiring kit us written to perform ,,functional test of the tow bar".
-Activate administration of program versions SVM.
-select function 3
-enter code and confirm
My question is what is it?Is it just a software update and does it have to be performed?
Also do I have to code CAN, BCM, engine, ABS, Park assist, Front assist after or before?
So I just found out its from ODIS software,so it does not apply to me as I will be using VCDS. Iam going to perform towbar coding from the ,,vcds tried and tested" section.
Anybody have anymore info about should I be aware of ......
