Power steering
Hi all new to the group and looking for some help or advise , I have mk1 fabia vrs 1.9 TDI I bought the car a as project knowing it had a few faults powering being the main fault.
G250 was my fault luckily a friend was breaking one so I got his sensor fit it no joy power steering still heavy and light back on , so replaced the wire from pump to sensor as I know it was good , still no joy so I because I had friend with a spare fabia I took the power steering pump and rack fit it to my fabia as I knew it all work fine on his ,started my fabia light has gone out fault has cleared but the power steering only work from the centre to left and back but nothing from the centre full lock to the right I have checked all wiring and live data I have topped the system up with correct fluid and bled it with cap on and off level is staying at max my current software code is 10140 I have read through this forum found other codes tried them but says coding rejected ? I've also tried adaption but its asking for a channel not sure what its asking ? And help or advide would be great thanks to anyone who reads I know it's long winded but I've been struggling for a while now lol and dont want give up on the car many thanks Tom.
Was the donor sensor/rack the same? Both twin pick up for a vRS?
Another thing to check is that the wrong bolt hasn’t been put into the rear lower engine mount. They are similar to another bolt on the gearbox but it’s too long and if done up it digs into the rack.
