changing coolant
quick question guys, would you open the tap to drain the coolant or the hose?
cheers :)
  • Sponsor
If there's a drain tap, use it.
thank oyu wino, i have heard if i mess with the tap it could cause it to leak. i have tried turning it but it wouldnt budge so i didnt want to break it.
do i turn it or do i pull it outwards?
thanks again
  • Sponsor
Turn anticlockwise as far as I recall.
 i will try again tomorrow, just changed my oil, was bit of a farce taking the under tray off 😞
i will just put bit more force when i turn it anti-clockwise, just bit worried i might break it.
  • Sponsor
You'll be fine.
Unlock it anti clockwise then pull it out to open the drain. Doesn’t drain the whole system.
thank you techie, once i got out as much as i can, i will fill it with water then drive around for a bit and finally open the tap again.
