Exterior lights not working properly
Need some help, when I switch my side lights there is no lights coming on and when i switch to my dipped beam lights only my dipped beam lights come on nothing else, the rear lights aren't working and no dash illumination but my drl lights are working fine, could it be a fuse blown or is it an expensive fix?
Check fuse 23 in fusebox under panel inder steering wheel.
Tried that and no luck 😣
It is possible the headlight switch itself is faulty...
Does the same thing happen when front fog / rear fog is switch on ?
Edited by UrbanPanzer
