Skoda Octavia diesel 2002
Hi
i have a skoda Octavia diesel 1.9 2002 modal. I m face the problem central lock when I try to lock by remote but not locking 4 doors, only lock and unlock  back trunk by remote. I went best work shop but couldn't find the problems i also change the driver door inside control unit but also not solved the problem, still i m face the problem ....
please help me out...
Probably the door wiring loom on the drivers side. A check with VCDS will identify what door modules are seeing the control unit and what state they are in.
From Karnataka
 Iff possible to install other central lock new from market
@Saleemulla - As Techie says, or there's a piece on the driver's door lock that can wear with similar effects.
