Yeti 2011 - led rear parking lights
Hi... did anyone mount W5W led without errors for rear parking lights? I do not succed with a few different led models..
I take it you mean sidelights.
Mine came with them as an option so I suspect it would be possible to select them as LED in something like VCDS.
It's all hidden under the byte 18 mystery. It's possible to code them in using VCP or ODIS-e but not VCDS I'm afraid :)
If I were the OP, I'd look to find some original LED units and have the car coded to suit.
I mounted without error W5W on the front lamps (parking lights) and interior lamps. For the Drl ..it is posible to work fine the leds which i bought. I will see...
Interior lights are not on the bulb fail warning system.
I know that..
