Buying a used Fabia
Hi guys,
So I am looking into getting a second smaller car and have picked out two 2012 Fabias.  both are 1.2L. one has 86K km and the other 115K km.  One is at a small dealer and the other (86K) is private and about the same price.
Any thoughts or advice would be appriciated.
Hi,
There are 1.2 Diesels or Petrols and different petrols and power outputs, so what are these cars?
You would be buying i take it on the condition of them and the servicing and maintenance history so maybe the km covered should not be the deciding factor.
1 hour ago, Roottootemoot said:
Hi,
Sorry, that is pertinent info.
they are both 1.2L petrol 44kW (60PS).
Well I went with the higher mileage one.  It seemed better kept and more service history.  It may have only been slightly sluggish on startup.  It has original battery and I probably old spark plugs as well.
I would still appreciate any advice or tip from experienced Fabia users.  Anything particular I should look into doing in the first few weeks, etc
 FYI/FMI:
option codes:
44KW 5G
CGPB
LF9R-1Z1Z
EOA 1DO 5SJ 5RQ 1KM 6FA 1AT 3FA
1N2 1NU H8P 4UF 4R2 3NC 4QU 4X1
4AO 8L5 J1P 7AA 8GD 6YO 9AB 8RM
7QO 8DR 8QL 8XO 4K3 BO1 GO2 QNO
3L1 9P3 Q1A 7XO 9WO 8WA 7AO 3GA
QG1 7MQ LO3 7PO FOA   354
Edited by hirez
ERROR
So, I am the proud owner of a 2012, 1.2l fabia with 115k.  I ended up going with this on because it had much better service history and Al's seemed to be in better shape. I even got a set of tires and oil change thrown in.  I asked to a cabin filter change as there was a bit of smoker smell, but was told only diesels have serviceable filters.   I had no idea.
I am asking myself if the spark plugs would be worth changing?  The engine seems fine but maybe not as smooth as it could be.
