octavia 3 reversing camera
i have fitted a reversing camera and coded it but i am not getting anything on the infotainment display ( Amundsen Navigation unit ) any ideas ?
ย
Need a bit more info that that, have you reversed pins 6 and 12 (feed from camera) has the camera got power, does the screen switch when you select reverse and there is just no video.
If you give us the info I am sure we can help ๐Ÿ™‚
ย
John
Hi
I have a 2015 octaviaย with an amundsen system, to start I had no screen switch I have managed to sort that by activating the camera code for the infotainment unit. The camera works fine my next step is to confirm pins 6 & 12, I guess if it switches as it does and is only missing an image the fault has to be camera related ? Thanks
Alex๐Ÿ˜ƒ
Did you reset the radio after the coding? You have to push the power button for 15 second (screen will be blank, release the button, when the Skoda logo appears)
Yes I reset the radio with no change, it is now working after i found a poor connection on pin 6. Thanksย
  2. Tap Permissions โ†’ Notifications.
