Changed clocks
Hi,I have changed the clocks on my 2011 2lt diesel yeti, it must have a immobiliser built in as the car won't start and the clocks are telling me the immobiliser is not set. Is it possible to say it and how, thanks for your help
Yes, part of the immo is built in to the cluster.
You may have also lost the ABS coding too...
Hi langers2k, I have put the original clocks back in, while it drives, everything is now flashing,  is this a trip to skoda or I wonder if the RAC can sort it
I doubt the RAC can recode an ABS module.
A Skoda dealer or indy garage with ODIS online should be able to recode the ABS module for you.
If you can post a full VCDS autoscan, it might be possible to come up with a code that's probably the same as stock.
I have just phoned skoda, if I take the new clocks in, they will recode and fit them for £80 so it's going in Wednesday,  thanks for your help
Are they new clocks?
