Cam sensor replacement 2008 1968cc TDI PD
Hi,
I have an intermittent Cam sensor fault and occasional cold start problems.
I'm getting a lot of confused info.
Are there two types two engine types  one with easily replaced cam sensor and one that requires cam belt removal.?
If so how do I identify the engine type?.
Also I read a topic that suggests that that cold starting is caused by a problem with the crank sensor not the cam sensor.
Is the cranks sensor easy to change. I don't want to be paying loads of money to change the wrong thing.
The quotes I have had are £134, £350 and £600 depending on what needs to be done.
Some expert advice would be appreciated.
