A driveshaft bolt killed my gearbox!
Hello all.
Last night my passenger side gearbox end driveshaft bolts decided to come loose. In the process one of the C shaped washers has punched a hole in my gearbox casing! I've asked the garage it was towed to to send me the codes from the gearbox casing but i can't decipher which gearbox I need?
The codes provided to me are as follows:
WWO
02Q301107
MGA19ZN1
Now from my research so far I can discount WWO as that is used on all VAG castings but I haven't found anything for the other 2 codes. Is there anywhere else to look for what gearbox code my car uses?
The car is a 2010 2.0TSI VRS and the gearbox is a manual 6 speed.
The gearbox code and the codes for the engine and all options are on a sticker near the spare wheel space.
And looks like this:-
I copied the photo from another thread. The gearbox in this example is HDV. Your code will be shown in the same place.
Thank you. This is a great help!
  • Sponsor
Has that driveshaft been off recently; for example for a clutch replacement ?If so, were those bolts replaced with new ones (they are supposed to be)?
