P0101 very intermittent
1.6 CR 105 diesel 2013.
Just looking for what more likely to throw up the fault code.
Under warranty, so ill be bringing to my dealer anyway to be resolved, but i dont want to get fobbed off either, or waste time with it not being sorted on first trip in...
Its only happened 5 times since i bought the car in April, 3 within a month/6weeks, and once around august, ant not since until today.
Ignition cycling resets it, and theres no change in power/torque/ fuel consumption because of it which is why i ignore it the first couple of times.
Today is the first time i had my obdii reader in and torque running on the way to work, interest in the running on motorway.
So, now in my head i know the likely cause, and how to get it to happen.
I came off the motorway, stopped at a set of lights, gave it boot to pull away, as it was a signalled roundabout with a short merge lane on my exit.
Aaaand voila! Flashing glow plug light.
Ran the fault scan and got
P0101 MAF sensor circuit range/performance.
So, which is more likely -
Maf dying, or a vac / intake leak somewhere that only shows up on a hard take off?
The other 4 occasions were both either on the braking up to or pulling away from toll plazas.. not sure when it came on as i was concentrating on the other cars, stopping point for basket and watching other lanes for safest/quickest exit strategy..
But today shows its definitely on the take off it throws up.
  • 4 months later...
Hi
Did you manage to solve this problem?
I have something similar P0101 (and P0402 sometimes), power loss/chugging, erratic idle, coil light on. Sometimes smoke after chugging.
So far, having spent hours trawling forums I've...
Cleaned MAF
Changed MAF
Cleaned DPF
Manually cleaned DPF sensor
Cleaned EGR
Tested MAF voltage
Had all the air hoses off, cleaned and looked for cracks etc.
New battery
Checked earths etc.
I'm running out of ideas - Maybe change o2 sensors next?
I haven't done a DPF Regen yet - that may help?
neither the code nor eml has come back since...
i also havnt even got round to the service as the last few weeks have been hectic.
hoping to get it booked in in the next couple of weeks though, may try and replicate the issue again this week.
i never got a limp mode though
Thanks for answering so quick macllirl
So the problem just went away? Did you have to do anything at all?
i cleared the fault code with mu bluetooth reader and  torque pro. it hasnt come back..
I've cleared mine several times... Fault continues and code comes back sometimes. Bleh!
Hey ho
Thanks for yr time. I shall continue my search.
did you get a genuine MAF when you changed it?
it may well be the egr is terminally goosed too..
