Towbar electrics
My 2019 Octavia has factory fitted towbar.  Should the live feeds for Fridge and battery charge Pins 9 and 10 be functioning ?
I would hope so but it wouldn't surprise me if they were not functioning
I put a meter on the pins 9 and 10 and they were not live. However when I plugged in a dummy 13 pin plug ( my caravan is in the south of Spain at the moment ) and accessed the rear of the socket, pin 9 was live and pin 10 was live when the engine was  running .... success
Is there a microswitch in the socket that senses the plug is inserted and activates the 12v supply on pins 9 and 10? If I remember correctly the same switch should also disable the high intensity rear fog lights on the car when the caravan is attached.
Edited by Liger1956
yes the foglight is deactivated as well. I was concerned that the electrical supply to 9 and 10  might not have been connected at the factory. I live in France  and it was supplied by Skoda France.
