Resetting service interval. (spanner)
Hi I've searched the site using different keywords but without success. 2010 Fabia 1.9tdi. How do I remove the little spanner symbol in my trip display please.
it might be as simple as twisting the clock spindle right and holding, then turning on the key etc. can't quite remember the routine. Is it the standard display or maxi-dot?
  • Sponsor
Page 18 of the Owners Handbook says:
The Service Interval Display can also be reset with the reset button as follows:
• Press the reset button with the ignition switched off and and hold it down.
• Switch the ignition on, release the reset button and turn the reset button to the
right. The service interval display is reset.
Its just the standard display. I'll give this a try, thanks.
Hi Wino, yes I have tried this and also the similar method given in the Haynes Manual so far without success. I also get the "Service" message when I first switch on. The service work is up to date but the displays were'nt reset at the time.
  • Sponsor
Have a look on youtube if you haven't already.
I always have to try a few things cos my Polo and the missus's Mk1 Fabia are slightly different to reset and I can never remember, but it's always one of the variants that someone's video'd.
I think its a twist, rather then a press so that might be the difference.
OH, I notice you added a twist at the end when I re-read! I know you are in the ball-park there, though.
Edited by mrgf
