Steering assistance fault
Hi fellas,
I know this is not my forum but I needed an active forum to solve a problem, I posted in mine but no replies for a couple of days. And besides  I bought this ibiza to replace my Octavia A5 2005 1.6 mpi
I tried changing steering response on my ibiza to comfort. But this messed up my steering wheel, it is very stiff as if there isn't any power steering and it messed other codes and whenever I try coding anything in this module it returns an error.
(22) function cancelled, marginal conditions have not been met.
Here is the latest error log
OBDeleven data log
Date: 2019-12-07 15:04
VIN: VSSZZZKJZLR020301
Car: Seat Ibiza FR
Year: 2020
Body type: Hatchback
Engine: CWVA 81 kW (110 HP) 1.6 l
Mileage: 3446 KM
03 Brakes 1
System description: ESC_base
Software number: 2Q0614517AE
Software version: 0242
Hardware number: 2Q0614517L
Hardware version: H13
Serial number: 08505898180808
ODX name: EV_Brake1BOSCHESPMQBA0
ODX version: 004036
Long coding: 530D4C573543CAAD32FFAC1634DB22A649124926226A245844 542254452C4465924892644456241A222A442AA22996431594 69C2A8
Trouble codes:
U111300 - Function limitation due to received malfunction value
Intermittent
Date: 2019-12-06 12:29:54
Mileage: 3330 km
Priority: 3
Malfunction frequency counter: 10
Unlearning counter: 213
Unknown ambient data: 0000000200A90000000001160000
static
Date: 2019-12-06 15:02:59
Mileage: 3337 km
Priority: 3
Malfunction frequency counter: 3
Unlearning counter: 173
Unknown ambient data: 0007000240A40000000100000000
U042300 - Invalid Data Received From Instrument Panel Cluster Control Module
static
Date: 2019-12-06 03:29:55
Mileage: 3330 km
Priority: 3
Unlearning counter: 163
Unknown ambient data: 0000000240B40000000001000000
44 Steering Assistance
System description: TRW_G4L_MQBA0
Software number: 2Q1909144M
Software version: 6041
Hardware number: 2Q1909144F
Hardware version: 611
Serial number: 1309413CB2K20320820
ODX name: EV_SteerAssisTRWG4LMQBA0
ODX version: 011016
Long coding: 010000000000000001000201010001010000010001
Trouble codes:
U112300 - Databus error value received
Intermittent
Date: 2019-12-06 03:29:43
Mileage: 3330 km
Priority: 6
Engine speed: 0 1/min
Vehicle speed: 0 km/h
System status: Reset
Terminal 15 status: On
Voltage terminal 30: 12.87 V
Power steering current consumption: 0.5 A
max.value: 16.5 A
End stage temperature: 33 °C
Steering assistance, engine output: 100 %
Engine angle: 276 °
Electric motor speed: 0 1/min
Steering assistance, target engine torque: 0.0 Nm
---: 0.9 Nm
static
Date: 2019-12-06 03:29:48
Mileage: 3330 km
Priority: 6
Vehicle speed: 50 km/h
System status: Cut_in
max.value: 16.5 A
Engine angle: 276 °
Steering assistance, target engine torque: 0.1 Nm
---: 0.8 Nm
B200FF0 - Internal malfunction
Intermittent
Date: 2019-12-06 15:23:04
Mileage: 3337 km
Priority: 5
Unlearning counter: 165
System status: Waiting for start request
Terminal 15 status: Off
Voltage terminal 30: 12.11 V
max.value: 0.5 A
End stage temperature: 215 °C
Engine angle: 0 °
---: 0.1 Nm
B7 Access Startsystem Interface
System description: VWKESSYMQB
Software number: 3Q0959435N
Software version: 1307
Hardware number: 3Q0959435N
Hardware version: 037
Serial number: 0520812458
ODX name: EV_KessyHellaMQBAB
ODX version: 004052
Long coding: 112E0E0703
Trouble codes:
static
Mileage: 3330 km
Priority: 6
Malfunction frequency counter: 2
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
Terminal_50_Kessy_specified_value: Off
Terminal_50_Kessy_actual_value: Off
ZAT_pressed: Off
Park selector lever position: Engaged and locked
Request active: Condition not met
Enabling steering column lock: Condition not met
Enabling immobilizer: Condition not met
No active error mode: Condition met
Key signature validity: Condition met
---: 12.851 V
Driver information key position copy workshop: not active
Driver information, roll warning: not active
Driver information, emergency shutdown: not active
Internal_key_position: no_message
Driver information comfort switching: not active
Vehicle speed: 0.0 km/h
Engine speed: 0.0 1/min
---: Vehicle unlocked
Approach to the inside: not active
Actuation to the inside: not active
Approach to the outside: not active
Actuation to the outside: not active
Pulling actuation, outside door handle: not active
Coding information: coded
Coding information: Not coded
Driver door: Open
Front passenger door: Closed
Left rear door: Closed
Right rear door: Closed
Active_LF_scans: Init
ID sensor 1 authentication, status: No response
ID sensor 2 authentication, status: No response
ID sensor 3 authentication, status: No response
ID sensor 4 authentication, status: No response
SPN_Byte 0: 0
SPN_Byte 1: 0
SPN_Byte 2: 0
Check the long coding in the scan you did before doing any coding and compare it to what you now have.
OBDII is well known for screwing up the coding in different modules when you use their ‘one click’ coding... ALWAYS change the coding manually yourself!.
Does OBDII give you a list of what adaptations have been changed?
There is a history file but it is huge i'll attach it.
I remember that the change was made through the adaptations of the steering assistance module on 5-dec at 18:15.
I'll also try to locate it in the history file.
But I have a question, what should I do when I locate it, the module already can't be coded due to the marginal conditions I mentioned earlier.
Should I try and revert all changes I have done in the car ? Though that will take a lot of time to detect all i've changed
0_history.txt
