Location of Exhaust Gas Temperature Sensor No3
Hi, I’ve just registered here in the hope of finding someone who could help me out with locating where the Exhaust Gas Temperature Sensor No3 is on a 2011 Fabia 1.2 TDI Greenline estate.
My Autel AL319 OBDII reader found the faults below so I bought a new sensor.
P242A -  Exhaust Gas Temperature Sensor
sensor circuit bank 1
Sensor 3
P242B -  Exhaust Gas Temperature Sensor
Circuit range/performance bank 1 sensor 3
I am very new to most of this but I’m very keen to learn and understand more about the car.
So far replacing cabin, air, oil, and fuel filter is the furthest I’ve ventured.
If anyone could point me in the right direction for the location of and the best access route to the sensor that would be fantastic!
Thanks a lot.
Gabs
I have the exact same issue, I'm hoping to fix it myself but it looks like its going to be a right pain. Does anyone have any advice?
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 L    HW: 03P 906 021 AN
   Component: R3 1.2l TDI   H07 9979
   Revision: 12005001    Serial number:
   Coding: 00114014032501080000
   Shop #: WSC 45977 001 1048576
   ASAM Dataset: EV_ECM12TDI03103P906021L 001019
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 313F12ACE1A3029F769-8064
3 Faults Found:
14126 - Exhaust Gas Temperature Sensor; B1 S3
          P242A 00 [136] - Malfunction
          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 182
                    Mileage: 162191 km
                    Date: 2020.01.17
                    Time: 16:40:37
                    Engine speed: 838.50 /min
                    Normed load value: 27.1 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 51 °C
                    Intake air temperature: 15 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 14.453 V
                    Unlearning counter according OBD: 7
                    Exh.gas temp.sen 1: 204 °C
                    Sensor for engine block temperature: raw value: 51 °C
                    Exh.gas temp.sen 3: 1000 °C
                    Exh.gas temp.sen 4: 152 °C
16973 - Exhaust Gas Temperature Sensor; B1 S3
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 12
                    Mileage: 162191 km
                    Date: 2020.01.17
                    Time: 16:40:40
                    Engine speed: 840.75 /min
                    Voltage terminal 30: 14.460 V
                    Exh.gas temp.sen 1: 196 °C
15536 - EGR Sensor 1
          P0405 00 [008] - Signal too Low
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 162259 km
                    Date: 2020.01.22
                    Time: 09:03:27
                    Engine speed: 976.25 /min
                    Coolant temperature: 28 °C
                    Intake air temperature: 7 °C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 14.265 V
                    Sensor for engine block temperature: raw value: 28 °C
                    EGR Vacuum Regulator Solen.val.: activation-PWM rate: 0.0 %
                    EGR Solen.val.: actual value-PWM rate: 50.2 %
                    EGR valve: offset closed: 10 %
                    High press EGR actuator: actual unconditioned volt val: 0.687 V
Readiness: 1 2 0 0 0
These are the codes I got. I think the EGR one was after the frost...I hope!
Half way down the Downpipe
  • 2 years later...
