Usin Lcode2 with OBDeleven?
Can I example copy the long code from OBDeleven and paste it to Lcode2 too check what the bit does?
Or is it not same values?
Got info from support of OBDeleven that the long coding is exact the same as VCDS. And its working to check values from Lcode2 and do the same in OBDeleven.
I have checked the long code save on computer and pasted in to Lcode2 and loaded correct LBL file and it shows what I have and what I can correct
