vw polo 9n high rev and white smoke
Hello My vw polo 16v have a problem when i run the engine anytime the revs are high and white smoke come at once after i rev. what must be the problem.
Do you know that there is a slight difference between Polo and Citigo?
Meaning citigolf?
  • Sponsor
Skoda Citigo and VW Citigolf are very different cars.  Google images is your friend.
Any help
38 minutes ago, Malume said:
Any help
Describe the problem more fully.
Skoda vw polo 16v?
White smoke means it is burning water/coolant for some reason.
So what could be problem when the smoke only come when you start the engine once driving there is no smoke.
Then there is no problem. That's what combustion engine does when cold.
If there is a lot of white steam your head gasket might be blown. It's burning coolant.
Edited by Emil
Are you losing coolant? Is there any oil in the coolant?
No its normal the is no oil in my coolant
Thanks letme monitor it
Burned head gasket does not always mix oil and coolant. Coolant can leak to cylinder.
Very true, but it is one of the 2 basic checks for gasket problems plus a gas check in the coolant if you have the kit.
