Central locking issue
Hello,
I just bought a Mk1 Fabia vRS and I am experiencing (among other problems) an issue with the central locking. The key fob works perfectly however the buttons on the drivers door do nothing at all. I can lock the doors from inside by pushing the cylinder thing down and pulling the handle opens it again just fine. Could anyone point me in the right direction of a fix.
There may be a wiring loom fault in the drivers door rubber boot, you'll need to remove the switch assembly and test for continuity between the the switch plug and the multi plug in the door hinge pillar where the door loom connects.
