Hesitation under load
Recommended Posts
Hi all
Hope everyone is well and good.
I've got a little problem with the vrs.
Under heavy acceleration when warm or cold. Whether dry or wet sunny or cloudy, towards the top end I've got a stutter and some loss of power
I've given it a good blast. I don't daily it my wife dose now as I have a company car
I'm going to change fuel filter, air filter, glow plug, oil to see if that helps
Anyone else had the same issue and know of a fix
It's a 2006 56 plate with 76k on the clock
Thanks in advance
Link to comment
Share on other sites
  • 3 years later...
How did you get on diagnosing the acceleration stutter. My VRS (2005) has just started doing the same. Push it hard and there is a noticable slight faulter like the fuel intake is not keeping up. I so hope it is not the turbo
Link to comment
It's more likely to be the MAF unless you've already replaced it.
Link to comment
1 hour ago, Mickthemiller1 said:
Thanks for the suggestion. I will give this a try.
All you have to do is disconnect it and see if it runs better, then you can replace it if necessary.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
