2014 vrs not starting
Hi guys wondering if anyone has come a cross this problem I have a 2014 Skoda VRS DSG when it is really cold the car will not crank and come up with esp abs and finally gearbox fault hooked it up on diagnostic and its loosing communication aprt from that the car drives fine after its warmed up will not cause a problem changed the battery still no good only code now coming up is steering angle sensor can any one shed light on this
Have you reseted fault codes after battery change?
Did you code your new battery to car electronic systems?
I resetted all the codes but have not coded the battery was going to get that done now but the car doesnt even crank when the problem starts could it be software update appreciate the reply
