Fabia VRS 1.9 Engine problems.
Hi guys.
Sorry I think I posted in the wrong place previously 🙁
This is my first post on here so firstly... Hi all and love the site, it a fantastic source of info and has saved me hours of messing about finding what I need and getting the job done!
Now, I am literally clueless here.
My brother in laws fabia
2007 1.9 PD engine
(think engine code is BLT but not 100% sure)
This car was running absolutely perfectly, not issues what so ever, pulling great through the gears, plenty of power no excessive smoke etc.
Driving along road, went from 2nd to 3rd and it just died, no reason, nothing to suggest it was going to do it, just died.
Call to the RAC, out they came, plugged it in - no codes at all to report.
RAC man gave the car a good look over, but couldn't diagnose the problem.
Car was recovered home.
Had a mechanic friend (qualified) spend some time looking at it and he has discovered the car will start but only with the oil filler cap or dipstick removed. Even the it smokes quite badly (from the oil filler cap) and it runs rough.
The mechanic has now diagnosed the car as needing a new engine as its has excessive pressure inside the engine.
Does this sound correct?
I personally would have thought there would be some kind of build up to this, if the car was running rough or had other engine issues I could kind of get my head around the engine being gone but it was literally perfect prior to this.
We would be grateful of any bodies input to this as really want to help him sort this out.
Many thanks in advance.
It sounds like the engine is kaput, last time I saw these symptoms it was due to a cracked piston.
Would the engine not run though albeit poorly with a cracked piston?
It might but then again it might not, it depends how badly the crankcase pressurises, in your case, very badly I'm afraid.
You're experiencing denial, it's a common reaction when facing a catastrophic failure.
Well, I'd agree that this sounds like a cracked piston. If you want to throw money at the diagnosis phase, you can use an endoscope or take the head off rather than just buy a new short engine.
Thanks for the replies guys, guess it's gonna be a replacement engine then, are these prone to cracked pistons?
Generally only on highly tuned engines but it sounds like yours is used and abused pretty liberally so...
It's been remapped by previous owner and modded a bit so may be where issue started. Have to find a donor car owned by little old man who drove nice and sensibly lol. Thanks for all your help.
