Starting engine
Engine not starting
Which engine?
1.4 16v
when I turn ignition engine turn over and cut out - not idling
Will it run with a bit of throttle?
no engine no running
10 minutes ago, Hazey said:
1.4 16v
4 minutes ago, Hazey said:
8 minutes ago, Hazey said:
no engine not running
Does it run for a second or two then cuts out?
First things first: Make sure you've got some petrol left in the tank.
Pay special attention to hearing the pump "priming" the delivery system when you turn the key to "on" (before starting the engine). It should pump for about 15 seconds. If not, it could be a dead fuel pump relay or a dead pump.
